anyone ever wired in aftermarket led lights?
jthemmer
Central Iowa
My viper has led lights in the grills and shock wells. However it was originally tapped in with my grip warmers when I bought the sled. I bought a new bar set up and am wondering whats the correct wire to tap them back into. Also they are 12v switched as well.
I have some LED's on my custom SSX I built if I remember right I hooked up to the headlight wiring and I installed a switch under the hood so I can turn them on and off if I want to. I also installed LED's above the front shock towers and in the rear around the rear bumper cover. If you need to know the wire color I tapped into I can look and let you know.
