Hi,
I have been searching around for the correct answer and it has been quite confusing.
I have a V-max 600 XT sled. It has now 89L-17641-00 belt, but I haven't been able to get one from anywhere. I have only came across to 89L-17641-01
Is the stock belt replaced with another belt? I could buy a new 8CJ-17641-00-00 belt rather cheap but should I give it a try?
Which belt would You recommend to be used
YAMMIEGOD3:16
GET THE 89L 01. YAMAHA HAS DONE THIS ON ALL THEIR BELTS. JUST DOUBLE CHECK YOUR BELT DEFLECTION. 3:16 (yammie tony)
