Cooper0809
I'm just wondering where the chain case oil drain plug is on an 88 enticer. Also, how much oil do I need to put back in? Is it 250ml, the same as the srx? Thanks guys.
I think the oil level is the same volume wise.
the drain on my 97 is one of the lower case cover bolts and the full line is with another one removed about 1/-14 the way up. sry do not have a manual for that year.
Yamaha Nutz
you must remove the cover to drain it
Cooper0809
Ok thanks guys, I guess I'm going to be making a bit of a mess. How do I fill it up?
should be a rubber plug on the side of the cover.
Cooper0809
K thanks maim, just realized your in Ontario as well!
yup yup. had to jog my memory a bit as the 78 et340 has not been apart in awhile.
Cooper0809
Maim said:I think the oil level is the same volume wise.
Well, the chaincase takes 0.4ltr. This is for model years 83-88. And the fill line is an Allen key bolt removed 1/4 the way up just like you said....
did not know that. we did have an 86 et340t but it was stolen before I had to do much maintenece on it. it was my dad's sled so he did it himself.
