82 SRV primary clutch shiv cracked
I believe the apex clutch would be the same size and taper, however the srv/phazer clutches have a boss on the back side that fits inside the oil pump gear case where the apex clutch does not. Basically the boss is a plug of sorts that keeps belt dust, etc out of the gear case. Also the offset of the stationary sheave may not work. The apex clutch may hit the frame.
Also, you would have to change your secondary set up to run a wider belt along with spring and weight calibration.. So, in a nut shell.... no you can not use the apex clutch on your srv.
