Srx 440 bellypan
y201srx
pa.
Anyone no a good way to remove dents from srx 440 belly pan. I no it's no easy task and I've seen some nice restorations most of the pans I've seen are dented so someone has to no a good trick thanks!
I have taken many dents out of these pans it all depends on how bad it is some only take 30 min while I have spent hours with some ....a good set of dollies and body hammers and them I have custom ground pieces of 2x4's to keep the edges right I like to use a sand bag or multiple layers of cardboard as a backer
Ok thanks alot for the info I will try those methods sounds like that will work well thank you
