tach for 250 Enticer?? Help
rvdave@live.com
ROCKFORD,IL
Putting a 250 Enticer oval sled, I read that exciter or polaris tachs wont work on a single cylinder motor. Is there any "used" tachs that would work? If I have to buy new is there any inexpensive tachs that work decent? I hate to spend more on a tach then the sled is worth. Thanks for any insights. Dave
all you need is a 2 pulse Polaris or cat tach like indy trail or indy 500 cat 530 eltigre fan cougars ...........hook the brown to a good cahssis ground or motor and hook the yellow up to you lighting coil which is also yellow coming out of the stator
Does that work on the bravos as well?
Polaris 2 pulse tachs can be found at most swap meets for $10 or less, just look on the back of tach and it will say "2P" or "2 Pulse"
I wire my yellow from the tach into the yellow in the wiring harness that goes to the head light....the brown goes to a good clean ground on the chassis.
