Do I have to get replacement hyfax from FAST or is there something else that will work?
Same as Polaris edge suspension.tnc110 said:Do I have to get replacement hyfax from FAST or is there something else that will work?
if it is a metric m10, they take the profile from a 1995 formula 3. I have a couple new sets left from when I ran one.
If it is newer style, I just use yamaha slides on it.
If you have a metric, about an hour of grinding and filing will remove enough from the metric rails to use yamaha slides as well.
BETHEVIPER said:if it is a metric m10, they take the profile from a 1995 formula 3. I have a couple new sets left from when I ran one.
Cool, thanks.It is a standard.
http://www.ebay.com/itm/360747590498?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
these are what I just bought, but the slot is too wide....too much slop. which ones should I have got?
