shaggyzr2
I am in need of a set of the stock pipes for my 2000 srx, were the pipes all the same on the 600s and 700s from 98-02?
not 98 srx all other years after are all the same
dragonsm
From what I found on my 98 when I tried to replace the can with a factory one from a 99, I found out the 99+ have sliding silencer joints. (or at least that is what Bluemonster1 educated me on)
98 pipes with 99 can
There's the link to the thread.
My initial advice (at least on 98's) is those pipes you probably want to steer clear of unless you replace the can also from a 98.
better look for 99 and up with muffler
shaggyzr2
Anyone have a cheap set in good shape that will fit my 2000? I have one pipe thats leaking, the others look ok but are pretty rusty. I was thinking about just replacing all three with a set that wasnt so rusty.
post it in the wanted section im sure someone got some or look in the classified section
98 all on thier own for both 600 and 700
99-02 the same with a moveable rear donut gasket to help seal to the muffler. you can spot these very easily as they have a bolt on them and the sliding clamp/gasket where as the 98 just has a permanet fixed little donut gasket on them.
