srx 600000 tripple
will a 2002 dash with the duel beam srx fit the 1999 srx single hood I am looking to get the duel beam headl;ight on my 99
staggs65
You'll need the windshield also. And the 99 stator doesn't have enough juice for the 2000 up bulbs so you have to go to a lower wattage bulb. do a search here there are plenty of threads on the subject.
staggs65
Also moving this to the proper forum for you, you'll get more responses there
if you run two hid bulbs with a battery, you have enough juce to run them. they are 70watt total. Snowbungie makes a battery designed for addon. you just wire them in with your smoothing coil.
A couple of bucks
What are the two bulbs that go in? H7...9004...etc
BETHEVIPER said:if you run two hid bulbs with a battery, you have enough juce to run them. they are 70watt total. Snowbungie makes a battery designed for addon. you just wire them in with your smoothing coil.
Scott, this is a add on battery to fire the igniters for std sleds?
