Srx crank question
09nytro
Grayling,Michigan
I'm working on an 99SRX 700
I pulled it down to check the crank and on the pto side the inside bearing on the crank moves side to side just like the outside bearings do . So my question is should that bearing do that to or no
Other than the side to side movement the bearing feels good I just can't remember if it should do that or not .
