TCviper22
Hey guys! What is the maximum chisel height one could run in the 02 viper?
Thanks in advance.
Thanks in advance.
richierich
Depends on brand of chisel.What brand you looking at ?
TCviper22
Stud boy.
richierich
YAMMIEGOD3:16
what track lug. 3:16 (yammie tony)
TCviper22
All I want to know is what is the longest chisel I can use that will not cause problems hitting the tunnel or exchanger. I will probably use a 1" track, but before I decide on track I need to know what the max chisel height I can get away with.
richierich
The 1.080" like i said.
YAMMIEGOD3:16
ya and most would need to know what track your useing. 3:16 (YAMMIE TONY)
staggs65
It's the amount of stud sticking out past the track lugs that matters so track size will dictate the overall stud length.TCviper22 said:All I want to know is what is the longest chisel I can use that will not cause problems hitting the tunnel or exchanger. I will probably use a 1" track, but before I decide on track I need to know what the max chisel height I can get away with.
