02YamiSxViper
Was aligning the front end this morning and noticed alot of play in my ski when the sled was off the ground. I replaced the bolts and lubed up the collar in the spring. I was looking at a parts list online and noticed theres supposed to be a bi-metal busing inbetween the collar and the saddle. Am I reading the diagram wrong or is there really supposed to be a bushing? The part number for the part in question is 90384-16251-00.
			richierich
Yes your correct theres a bushing in there.Two of them per ski saddle/spindle.
			02YamiSxViper
Are they pressed in or do they just slide in? Would this be a likely culprit into the play on my skis?
			Cooper0809
Yes that would be why there's play, if you can see that's where the play is coming from....should be able to see a gap on either side. I just got 2 washers and put one on either side. Problem solved!
			02YamiSxViper
So I tried adding washers as you suggested with no luck, skis still wobbled like crazy. The sled has 13000km on it so it was probably time to replace the Bi-Metal bushings and sleeves anyways. I ordered my parts Friday and they should be here by Tuesday. If anyone is having problems with darting and their skis and loose this could possibly be your culprit.
So I just used a cold chisel to get it started
Then I ripped it out with some plyers
The one on the other side I just used a 3/8" extension from a ratchet and hammered the bottom one out, came out easy.
I don't have a picture but I'm 99% sure this will fix my problem. One of the bushings was substantially more worn than the other. The sleeve has also seen better days. Now I just have to wait for my parts and hope this was my solution.
