Ex 440
3g racing
fayette ohio
Will a gear and chain set from enticer 340 fit the exciter 440 I was wondering if the 340 gear would be better for 500' grass it's a lower ratio
Preaty sure they are not the same. Exciters were tripple roller and I think Enticers were double. Drivers are also smaller on the ET so don't asume the gears alone make up for the lower drive ratio.
opsled
Enticers had a double roller chain, diff chain case, square driveshaft (not sure if splines are the same) different track pitch, and I'm pretty sure that the top gear has a smaller inner diameter.
