Have a couple triples.. 97' 700 SX & 00' 600 ER, I'm thinking of using a wire under the steering pads but don't know which color wire is best for this app?
thx
thx
blue wire
SRX500kid
Take the brake light wire connecter apart and take the prongs coming up from the sled (just easier) and wrap the positive wire for the shield around the blue wire prong and the negative around the green wire (ground) prong and put connecter housing back on and connect it back up. Quick and easy instal. Just check for 12v AC at the shield plug.
iPhone using Crapatalk
chris700readhead
I have mine hooked to the key so my shield only has power when I have the hand warmers on.
I'm at it this w/e..anyone else endorse one of these rigs?
roudyroy1
i went to the reverse beeper because i couldn't stand it!!!
on the 01 600ER went right on the battery..97' sx700 found blue and green under the pad and tapped w/3M snap joints..hope this shield improves the ride quality..I did have some fogging issues last year.
thx for all the good advice.
rx1jim
I always put an fuse in the circuit running to any accessory. They are inexpensive and good insurance to protect the electrical circuit. I tape a spare fuse to the outside of the fuse holder. I also made up a test light which plugs into the connector for the heated sheild. That way I can periodically plug it in to make sure the circuit is powered. I have had problems with the cord going from the electrical connector coming from under the handlebar pad to the sheild, the light let's me pinpoint the problem quickly while out on the trails. I carry a spare cord while on the long saddlebag trips just in case.
Jim
Jim
