dangrs1
Right now my sleds are in two different states. I was thinking I should replace the battery in my '06 RS Venture to be safe since Yamaha couldn't spend the extra for a pull start on it. My "new" 2000 Phazer Deluxe came without a battery. Will my old RS Venture battery fit in the Phazer? Since the Phazer has a pull start if the battery fails its no big deal.
might have to customize the battery box a bit for it to fit. I had to mod the battery box on my enticer to get an rx battery to fit in but it works awesome.
dangrs1
Does everybody stick with the Yuasa batteries or are there better ones out there?
super1c
Super Moderator
I personally believe unless your buying a special gel battery or something similar they are all the same. Treat them well and they will be good to you. I just use reg batteries and get them from Napa. Cheapest I've found and been running the same batteries for years.
