Airbox to frame bolt size 2004 Viper
Racing666
Vermont
I lost a bolt and would like to know if anyone knows the size bolt that goes in the airbox to steering frame? The part number is 90119-06163-00.
If I knew the bolt size, I would just go to the hardware store and pick one up. I have no idea what the size is though. Maybe 7 or 8mm?
I checked the parts fiche to verify that the Viper and SRX are the same, and they are, so I pulled an SRX bolt since the sled was readily available.
In addition to the 10mm wrench, the thread size is M6 (6mm dia) x 30mm long. I don't know the thread pitch, but I bet it is whatever is more common. If you're going to a hardware or automotive store, they may have only one thread pitch spec to choose from, and even if they have two you could just buy both bolts since they likely aren't too expensive.
The bolt also has 2 integral/floating washers, a split lock washer under the head and then a flat washer. The flat washer is just under 17.7mm OD.
