1999 sxr edge suspension
Sxrnut
New Hampshire
1999 srx edge suspension swap
Hi, I know that there has been a lot of posts on srx suspension swap, my question is which edge suspension should be used? There is a 2006 edge 544 500 suspension I can pick up cheap, will this work? What are you guys recommending? Thank you
All edge suspensions are pretty much the same. Go for the one that is in the best shape and best shocks. I'm swapping one in right now.
yammitrip1 is correct that they are all basically the same except the shocks. There is the proX that is a heavier duty version but from what I understand it is for racing/ditch banging and is not smooth on the trails. I did the swap in my viper last year using the measurements from pioneer and everything works great. I am pretty happy with the results, it is much easier to adjust and has far more transfer.
