help asap powervalves
barkerman77
Madoc, Ontario, Canada
I decided to clean my 02 sx viper valves tonight. Found that one cable pulled out of the end of the valve. The cables fine the valve is not. The valve also looks like it made contact with the piston. I DIDNT think that was possible. So now I need a power valve asap. Were getting snow right now here in Ontario finally. Does anybody know why the end of the valve is marred on the two corners of the "U"?
And where can I get a valve. Does anybody have one kicking around?
try to find a used one,and maybe one with the SS end.If you go to the dealer here,look at $125 plus dollars for one valve.Also valves off an SRX are different then valves off a Viper..don't get the wrong ones if buying used...
