Jealous!
I can't beleive you got to drive
Vibration at high speed?
Took it out again to get a feel for the vibration.
It only seems to be at low speeds when decelerating. Feels/sounds like it's coming from the rear of the skid. Sorta like a drone. I'm just thinking it's the noise of the track. Never had a track with studs before
I know the skid is good. I went over it and changed everything that needed replacing.
Maybe your good to go then
staggs65
Is it a new track? If so what size lug and did you check the clearance on you exchanger protectors? may have to trim the track a little over the windows. Also if you put new slides on it check to see if the slides are hitting the clips as the track turns around your rear wheels.
if those check out it could very well just be the track noise. send some snow this way
horkn
If you didn't taper the end of the hyfax, that could be the case. I only run studded tracks, and never have had any noticeable difference in vibration studded or not.
The ones I bought were cut to size and already tapered. I have always tapered them before when I did cut them down.
super1c
Super Moderator
How is your belt? If it was left on all summer a flat spot will do the same.
belt was left off all summer, I tried two different belts. its not all that noticeable I think im just alittle paranoid.
gotta wait till we get more snow to really try it out
think it would be the studs hitting the drive cogs?
staggs65
By you're original post it sounds like you didn't change your driveline bearings when you had everything apart. Did you at least clean, inspect, and repack the bearings?
staggs65
Even if that's not it you should check them. very easy to do and not worth the chance of not doing.
