Rear suspension help
SRX98Bradley
Albany, NY
Im looking to get the rear end of my 98 srx up higher. It has ohlin's suspension all the way around right now. Is there a rear shock out there that just bolts in and is stiffer and will raise the rear end up?
No fabrication for the rear suspension. shocks will bolt right in. 98 you should already have the long transfer rods, you might need the limiter straps too.
Front shocks is a different story.
yea i have the ohlins in the front and i have viper rear suspension but previous owner replaced the gas shock with a cheap shock for some reason, so im just looking for a rear viper gas shock if u or anyone u kno has one. Thanks
