I have a set of ski's from a 2008 Yamaha Nytro that I would like to use on either a older Phazer 2 or a VMAX4. Is there an Adapter out there I could use to make these skis work?
rx1jim
Pretty sure you will have to make a pair of custom brackets to mount the Nytro skis on the pogo style front suspension of the phazer or Vmax4. I made a pair of mounts to put a pair of 2000 SRX skis on my 1993 ExciterII.
Jim
Jim
what I used to do was use the srx ski's on the phazers,etc with pogo stick front end. just unbolted the aluminum bracket and milled out the center letting the strut tube go down far enough to align up the mounting bolt hole. I think you could do the same thing with newer plastic ski's but youd have to mill out the center again to get the mounting hole to line up. You could do it on a bridgeport with a milling end on it.
Youd need to measure how far down the mounting bolt hole is from the ground(sled sitting on floor with no skis on it) and see how far that is. Then measure the ski to see if theres enough meat (plastic) there to mill out the middle some for the strut tube bracket to go down into.
