1994 VMAX 600 TORS issue
Zack1978
Hi everyone,
I just picked up the used 1994 VMAX 600 with 1,900 miles on it today. Well the one issue I have run into so far is that when I gave the sled full throttle, it bogged down and almost cut out and the TORS light lit up on the dashboard. Any ideas as to what might be going on? It seemed to run good otherwise.
Thanks,
Zack
Check trottle cable freeplay. Spec is 2mm at throttle but i have found they like to be run much looser then this on older sleds. Maybe a wear issue??
Also, check the tors switch at the carbs, I had to replace the button it hits when you let the throttle, and this was on a 8 year old sled.
