srx timing tab
modsrx
canada,qc
I would like to know if the timing tab in a srx is the hole on the top of the pull cord crank...how does it work does it align with the big notch on the flywheel
I am curious also. When I recently installed my fly wheel it seemed like their could be a few degrees of adjustment available before you tighten the nut ?
Or will it self center as you tighten it ?
i ask cause i change the system for a 2000-up ignition.... that need to relocate the the ignition trigger ...
