5.350 wheels for srx
t-rav
hanmer,ontario
Hey guys I bought 5.350 inch idler wheels for my srx but the bearing is bigger then the bushing that goes in there the wheels take a 6205 bearing and stock idlers are the smaller 6004 bearings what suggestion do u guys have to fit these wheels thanx guys
They are billet wheels from mountain magic but I think I got it figured out I need a 6304 bearing same outside diameter as the 6205 at 52mm but I need a 20 mm inside diameter wich is the 6304 outside is 52 mm and inside is 20 mm thanx guys
I never did the bigger wheels, I am sure it helps.
I think the betheviper set-up for the rear skid will reduce even more rolling resistance. He has a great write up on it.
I used the 5.35 wheels on the 128" SXR I used the Polaris versions. Exact fitment. I noticed a decrease in rolling resistance and limited hyfax wear. I am replacing all of the idler wheels on the rest of our skids with 5.35 wheels. I have heard that they will slow you down at WOT but I am not into racing. Al
