sxviper32
i got a big bore on the way and i need some more cooling capacity. can i just tap into the line under the hood and put a small radiator or no? also, can i take out the rear heat exchanger and put in a tunnel u-cooler so the running boards would feed into the u-cooler and back to the other running board cooler on its way back to the engine. any suggestions? please help!!! thanks!!!
