Was test riding the sled a few days ago and my track ripped and spit out in the process it bent the adjuster so I bought a new one replaced it and the track now the track sits on the skid "crooked" the right front lugs are touching the slides, 3/4" at right rear, 1/2" at left rear and, 3/4" at left front. So I bent my whole skid? Any input would be great thanks
BETHEVIPER
Life Member
maybe the front of your rails are bent over. If they are, you will want to pull the bolts on the front lower shock mount and check for cracks. when the front of the rail bends sideways, sometimes it will crack under the washer.
below is a few things to check out if you have the skid out, also in there is the correct procedure to remove and install quickly.
if you can, pictures sure help
Got some time lastnight and took the skid out whole thing is shaped like a diamond... The w ARM has definitely been welded guessing it wasnt straight so time to start replacing parts. Thanks for the help
BETHEVIPER
Life Member
read my skid fix thread to make the skid much better than it was new. if you need any parts along the way, I have several skids apart and ready to ship whatever pieces you need.
