Bender lite weight primary cover
I've looked at that too and wondered if it was worth the price.I believe the biggest advantage to them is the larger bearing surface vs the stock fiber bushing of the oem cover,it's supposed to keep everything parallel better with less chance of binding.
If it is the old 911 parts, i think it also has threaded wholes inside for balancing your clutch with the cover.
