lehula
the manual lists the different patterns, but I don't know what the patterns mean because it doesn't say. I believe my pattern is .75 seconds on and 2.5 seconds off. It does this continuously after the initial 3 flashes to check the bulb. My manual recognizes this pattern, but doesn't say what it means. It is pattern number 3 in the manual. Thanks in advance.
Devilin AblueDress!
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/FaultLocationCodes.htm
Tech page link. I don't THINK its supposed to do the 3 to check the bulb if there is another fault code found.
Devilin AblueDress!
Based on your description I would think grip warmer
lehula
Yes, it looks like the grip warmer. thanks you so much for posting that info. I don't know why the manual would show the patterns, but not the definition.
roudyroy1
so the dealers can make money!!!
lehula
Yes. I noticed in the manual, it tells you many times to take the snowmobile to a Yamaha dealer, instead of telling you how to fix the problem. Cha Ching! I'm sure, there is liability issues too, but I would rather believe the conspiracy.
staggs65
Are you talking about the owners manual or the service manual? the service manuals shows the patterns and what it's for
lehula
I have the clymers pdf. It doesn't say anything about the codes that I know of. With pdf, you can do ctrl+f and it found nothing.
Backwoods M Max
You have to get the factory PDF for the sx sleds. I was worried about an overheat all the way back to the truck, putting snow on the running boards all the way back. Turned out to be a grip that the glue came loose and when I twisted it the wiring broke. The fault was intermittent which was even more annoying. I now have RSI stick on heaters with grip wrap over them.
staggs65
Yeah ditch the clymers. I know how you can get access to the actual Yamaha manuals in PDF cheap
