Tell me what I have please
IgoFast
Wisconsin Rapids WI
Ive got a 2000 srx 700 with stock motor
it was clutched before I got it I was wondering how this set up is and what it was set up for.
Rear secondary clutch has Hauck Powersports G 49/41 Helix with black spring Green dot in number 6 hole
Primary clutch has Orange spring with black lines.
Not sure of the weight of the weights or rivets
Engages at around 4800 and it engages super firm
Any clues?
sounds like a Hauck clutch kit, sounds like their primary spring although their secondary springs are usually painted. you need to check the #s on the weights before anybody will be able to give you an idea of what it will do best.
Hauck numbers his clutch kits. I have seen from #1 up to #4. Of corse #4 being the best and or most. My guess here this is a #4 so weights probley been changed. This is a go fast set-up. 3:16 (yammie tony)
