ecopter
I'm in need of the small plastic washer that sits on the top side of the throttle, but just under throttle itself. On the microfiche, the pics show a washer/special (85GT-83663-00-00), but it sits underneath on the bottom side of the lever. There are also caps that are shown (85G-83956-00-00). It may be the caps I need, but a description of the part is semi-clear plastic that allows the throttle lever to side easily (plastic on plastic).
Let me know if you can get this and I'll shoot you my information.
Thanks,
Jon
By the way, I'll need two of them.
jf
Thanks,
Jon
jf
if you need two of them then it is the white plastic pieces that keep water out of the block.
i have some. how soon do you need them? i can throw them in a letter tomorrow for you, might take a few days to get there.
Port-Parts
Jon
I believe you need the caps. I don't have them in stock but should be able to get them in a day or two. They sell for $1.33 each. Give me a call if you need them. Thanks
ecopter
Much appreciated on the quick reply.
Thanks,
Jon
Thanks,
Jon
