rockwatersrx
Is it possible to run a regular gear 37 tooth in a chain case that is fit for reverse?
Looks like I would have to eliminate all the reverse gears and hardware, but it looks like it should work.
I'm Willing to sacrifice reverse to have this 37 tooth sprocket in there.
If anyone has done this give me your thoughts
super1c
Super Moderator
Yes it will. The cases are interchangeable. You just need a few spacers. Just look up the case on a parts diagram.
rockwatersrx
I've got the gear in place, seems like all I'm missing is the different bolt that hold the gear in place. Everything seem to be matching up I'm not sure if I should just run it.
Now you got me thinking about spacers, everything seems lined up perfectly.
super1c
Super Moderator
There should be a spacer behind the gear.
