stealther27
Alright so today I got my primary clutch removed and awhile back I got some new duralon bushings for the primary clutch rollers. And so my ? is what is the best way to remove these bushings from the rollers and replace them?
Rustman
stealther27
ok I don't have a press but one of my buddies does I was seeing if anybody had any tips on what else works for this job if I cant get to a press right away?
well the only other way is to use a bench vise. Youd need a sleeve to use to press the bushings against, and then a cup/socket,etc, thats the same size as the roller to press the bushing into.
stealther27
alright wellit sounds like then my best bet is to just use a shop press then.
