J
jaydougempire
Guest
Ok so i bought this 2002 viper. Got it home and the first thing I did was pull the pipes, manifolds and powervalves. Wanted to have a quick look inside. Everything checked out except my PTO powervalve cable was broken right where it goes into the guillotine. I bought a used one in good shape. Going to re-install these bad boys and I am concerned about the location of the servo motor. I had to pull all the cables to get the PTO cable out unfortunately. I did not mark the servo location before it moved on me. I have re-installed the P.V.s and heres what i did since i had the pipes out... i hooked the cables back up at full slack. i turned the servo by hand counterclockwise as far as i could until there was no play in it. i then reached my hand into the exhaust port and snugged each cable until i could feel each guillotine was perfectly flush with the top of the exhaust port. Should i be worried that the servo is not in exactly the same location as it was before? is there anyway to check this without running the sled? any tips would be much obliged. BTW i am brand new to this site so forgive me if im posting about something that has been covered before. i tried researching and wasnt able to find an exact answer. Thanks!
