enticer300longtrack
hi, i have an old 1996 indy 500 with extra 10 suspension and a 1.25 ripsaw 2.52 pitch. I have a 1983 enticer 300 that i want to be a longtrack, anybody think i can take the drivers from my indy, the suspension and track and put them in the enticer? it needs a track and i can find one that will fit it, its an odd ball size.
Devilin AblueDress!
I would say the drivers/driveshaft will be the tricky part. I have no idea what the indy has for a driveshaft but pretty sure the whole shaft wouldn't or shouldn't bolt right into your Enticer. If the Enticers already has 2.52 drivers you could re-use them (may need narrowed/widened to match track) If both driveshafts are the same size drivers could be swapped around or you may have to find 2.52 drivers to match the Enticers driveshaft.
horkn
Yeah, I doubt the drive shaft will be interchangeable.
track and skid no problem, with alterations. dont think your hex shaft poo drivers will hold on that square driveshaft, but you can get the correct drivers from kimpex and do it right. did a similar with a .92 track off a vmax along with an srv skid in an 83 enticer.
gotta build your self a custom tunnel extension and toss in a bumper. some lift in the front helps a bunch as does plastic ski skins. makes for a riot of a ride, besides the handlebars.
