hereismylife
03 Viper E/R
136 track
2 layers of head gasket.
Amsoil
Has about 500 miles on it. We were riding for about 2 hours yesterday. at the end we pulled up and backed sleds into garage and shut them off. it looks the same way it did the day before when I pulled the plugs and looked at the pistons.
What do you think?
136 track
Amsoil
What do you think?
YAMMIEGOD3:16
started out spot on perfect but seems to be alittle grey/white starting. i would up main jet slightly. 3:16 (YAMMIE TONY)
hereismylife
started out spot on perfect but sees to be alittle grey/white starting. i would up main jet slightly. 3:16 (YAMMIE TONY)
I updated my post description. Just noticed it only has 2 layer headgasket. What makes you say the main jet is lean instead of the needles?
staggs65
was this run right before you pulled the head? The wash looks good to me but the crown looks a little dry. If this was setting a while before you pulled the head and took the pics maybe the fuel just evaporated away?
hereismylife
Once we were done riding backed it in garage and 4 hours later head was off.
