power valves removing pipes
captnviper
Lifetime Member
st paul
Friend of mine has a mish mash between 98 and 99 srx power valves. cables are from 99 and motor is 98 mounted to front of airbox. Tried adjusting the valves by turning down the idle but that way ended up turning adjustment screws nearly all the way in. so wanted know the procedure for manifold removal. thanks
are the cables wrapped the right way on the pulley? take a pic and post it....
