hessracing
Hey guys im trying to get my problem figured out with this can i bought it used on ebay do i just bolt it on and go? am i supposed to set the air screws differently? chris red head thanks for the help on the last post does anyone know what the turns are in or out? or do i just leave it set stock? it seems to be loading up on on bottom end my air box is gutted no center plastic piece or foam thing on the top and the pipe doesnt seem to fit the best anybody have issues with this before?
Terrence R
The air screws are recommended to be set at 2 turns out regardless of a cann or not. That's two 360 degree turns on each carb. Turn them in all the way, not too tight though, and then turn out the 2 turns. Chances are, they're prob already set to that anyway.
I have a new mbrp cann that I decided not to put on my sled. It too didn't seem to fit on 100%. But it was not too bad. If you're concerned about it leaking at the joint, just use some high temp ultra copper around the donut gasket. Hope this helps.
hessracing
Thanks for the help Terrence! I'm thinking im going to have to pull it apart again and check!
shaggyzr2
That would be a fuel screw, manual says 1.5 turns out, I've got mine at 1 3/4 out.
hessracing
im hearing its defintily not out far enough sounds like im going to have to pull the carbs im almost positive there in stock position hope it takes care of the issue!
sleddineinar
For just an aftermarket can you should be able to leave it where it's at, as long as it's set right to begin with.
hessracing
Thats what I figured when I did this with my srx I had no issues at all i never had to mess with any of the settings on my carbs this one on the other hand any speeds below 20 miles per hr it sounds like the choke is on and it back fires kinda once its moving it runs great good power and all and idles fine i think that having the air box wide open may be affecting it too
sleddineinar
The gutted airbox might be an issue, most guys don't like them. I've only heard of a few that haven't had trouble with them gutted. The jetting probably should be bumped up when gutting the airbox. With extra air I would think you should richen it up. But I've never messed with gutting the airbox. Maybe someone else would know more about that.
hessracing
When the stock can was on it ran fine no issues at all with it being wide open and now just at slow speeds im having the issues 0 to 20 it sounds like the chokes on then clears right up
sleddineinar
what are your current setting in the carb?
hessracing
honestly dont know i believe they are stock hoping to dig into it on friday!
Backwoods M Max
I run an mbrp race can with vForce reeds and reed spacers. I'm fine on jetting, but I did raise the needles 1/2 clip to be safe and she seems to really like it that way.
hessracing
Hey guys I pulled the carbs off and turned the screws out 2 turns sled runs much better on bottom now! gotter all fixed thanks for all the help guys!
