rnloutdoors02
so I got my viper back from the dealership from a preason check up. Took it for a little ride runs great until you let off the throttle. Then when you try to get back on it it just bogs down till you stop then it idle down and.boom runs fine untill you let off. I changed plugs and each cylinder is. getting spark so I don't know what to check next. any help would be appreciated thanks
Could be TORS kicking in. Check your throttle cable adjustment, it may be too tight.
yep u need to slack that throttle cable ...u need to have some free play in it
rnloutdoors02
Alright I'll check that next. Thanks for the input
rnloutdoors02
quick question probably a stupid one but how do I exactly adjust the cable.
check at the carb u will need to unlock the nut on the cable and screw the cable in and lock the nut again
rnloutdoors02
Thanks, I'll give it a shot tomorrow and keep ya guys informed if anything goes wrong
mile9c1
Carb heater turned on?
rnloutdoors02
I adjusted my throttle cable. it was super tight before. hopefully this fixes my problem. il test it out once I get my new recoil rope
