2002 mountain max
Hammer Down
Flint
I saw a nice sled on Craigslist. It's a 2002 mountain max w/136 track. It says deep snow special on the hood. What engine is in this sled? Is it a viper or srx? Don't see many of these.
Any pics, or link to c-list post?
Only mountain SRX was 1998.
Yamaha did offer redhead 600 & 700 mountain max in 2002. I don't think they offered Viper mountain till 2003.
I have a 2002 mountain max, here is the rundown on it: 141" 2" paddle track, 600/700 sx (redhead) engine. Has the 2000+ skid improvements and geometry. Only problem with the stock sled is the track. It has a horrible pattern and the durometer is too hard. If it has been trail ridden then the track will start throwing lugs like mine was, it's only a matter of time. Set up properly (limiters, shock preload) it can be pretty capable as a hill climber, but if you want to just bust drifts in a farmers field it will be a blast as is. If your willing to invest into it, you can go full blown mod sled and end up with a very capable sled for about half what a new mtn sled will cost. It will out run most modern 600's and can hang with the 800's. You can't beat the torque of the 700 triple and it will never leave you stranded.
Full run down on mine: 151" track, rail ext & tunnel. Bars/risers/t-post. Light weight can. New skis. Stripped skid. Low windshield. Custom seat. Into mine about $5000-5500, paid $2000. Biggest bill was the track swap, $1800 parts and labor but I was a chicken and wanted the dealer to do that part. They ended up doing full driveline bearings and a chain so I'm glad they had it to look it all over. Probably shed about 35 lbs by the end.
That particular example looks beat though. Not a deal breaker as long as nothing is tweaked and the motor is healthy, anything can be fixed. Trailing arms look beat with all that rust, radius rod is bent on the right side. Rear susp looks to be sagging way too much, snow flap shouldn't be touching the snow like that with no weight on it. I'd point out the flaws and offer if $1500 if you really want it, less if there are other problems. Blue book on it would be right around $2100 before the damage and flaws.
