In process track replacement i got a question
0srx0
Rogers,Mn
So I cannot break the bottom bolt loose on my bottom gear in the chaincase. Any suggestions before I break something?
put the chain back on & the top gear, then pull brake lever and turn bottom gear first then top...that way the drive sprocket wont just 'spin'
I'm able to hold the driveshaft and keep the gear from spinning while using my electric impact but I will give that a shot. I did use the brake method to get that top nut off but this bottom one is on there pretty good it seems.
So I put the tensioner back on and used the brake to do that bottom bolt and it worked good. Used a breaker bar this time though. Thanks for the tip!
