This was / is a more common problem on the Vipers. If you do a search on here, you will find some good reading that should help you. I bought an '02 that had a water pump leak. Got to use the loctite trick on the impeller (you will read about this in the articles you find). Also - I was able to do mine without pulling the engine. Really wasn't too bad at all. Just take your time and be diligent about following the instructions others have posted. Good luck!
