I don't know if this will help you but... just finishing up a '99 SRX that has been VERY neglected. With plugs lying on head, pulled motor over, pto perfect, center and mag cylinder would SLOWLY loose spark until they would not fire?!? All 3 coils are supplied power through the same source and daisy chained together. I'll try to keep this short, (1) rusted flywheel - cleaned up but was so bad it's pitted, (2) clean pick up coil, (3) chased harness thoroughly for rub through's etc, (4) removed coil pack cleaned everything in varsol, (5) check caps for resistance values. Put everything back together, plugs sitting on heads, pull motor over. BIG FAT BLUE SPARK on all three, then... same thing, slowly loose spark on mid/mag cylinders. WTF, then I saw something, small blue arc on the middle of the coolant rail all by itself. Got my son to come out and pull the motor over so I could see the other side of the motor and sure enough, wires were arcing all over the place. If you can, try a different coil pack, they may be breaking down? Sure had me chasing my tail...
