roudyroy1
what kinda top end are you guys getting on your red heads? im getting about 150 kph on my stock sxr
attackandsxrowner
That's typical of what I've seen
What kind of a gearing and track do you have? On good conditions, I can get up to 140 kph on my MM, so I'm thinking yours should do at least 170.
MBtriple
on the river the dream-o-meter showed about 102mph. not sure how accurate that is though.
devinzz1
Ive hit 170 on my 97 slightly modded. Its been cut down alot since gearing down and going with a 1.875" lug track
sleddineinar
Mine has pipes & I run 21/40 gears and a 144" 1 1/4" ripsaw. Top-end is usually around 103mph on the gps.
roudyroy1
upon looking at the sled the next day, my belt had blown and lost the top drive cogs so with a new belt im sure it will pull around 160.
roudyroy1
put a new belt on and got about 155, im over revving at top end though, 9000 rpm. what could i do to bring that down to 8500? would i get top end by getting it to 8500?
Backwoods M Max
Clean your sheaves and give the belt a couple hundred miles to break in.
