tractordanp
Just picked up a 2000 sxr 700 for the ol lady for 500 dollars has 1735 miles on it with new track was not running
went through the carbs yesterday they where real bad it fired right up and runs great
only problem is oil light stays on steady it does flicker when up to speed oil tank is full
bad sender?
what can I check
thanks dan
bad sender?
what can I check
thanks dan
Dan,
I have the same exact problem.... did you end up replacing the sender? I think that's what I'm going to do.
Dennis
Dennis
yep my buds did same thing...replace the sender
YooperMike
Sender. Or just ignore it and make sure to fill it up at each fuel stop, which is what I do.
