2007 Apex TORS issue
horizonls
Ottawa,Ont
Any ideas how to fix this issue? last 2 rides I have had the "check engine" light & triangle warning lights come on and the sled displays same issues as TORS but, there are no codes ( 84 TORS or 42 TPS ) What is wrong..?
It slows and limits RPM just like TORS
I think it is TORS but no codes.
I can ride for 15 mins with no issues then it happens and I have to wait 30 secs by the side of the trail for it to pass then start riding again..??
May want to post this on ty4stroke.com, may have better luck than here in 2 stroke land.
That said, bypass TORS and see if your problems & lights go away, and that the sled runs ok. If so, fix the TORS issue (start by checking for throttle cable for too tight) and hook TORS back up so you have this safety system in place.
