383stroker
I was just wondering if anyone has tried a set of bender big bore trail pipes and a 700 trail ported srx?
they work good but you dont need them until you get the engine up to 165hp output, otherwise the stockers are better due to the insulation and very wide torq. curve.
if your building a good trail/lake srx with ported case and big carbs(38mm) the bender pipes work great! Youll get a good gain with them on a engine like that. the stock pipes are flat out done at 165-168hp, they wont give any more no matter how much engine work you do, they are just done flowing enough.
383stroker
Ok that's what I thought I figured someone has tried it. I have a set sitting on the shelf I was just wondering if they worth the time to put them on it. Thanks a lot for the info.
