Replacing primary spring
Just be careful that you don't pull the threads especially at the very end of the last few bolts, the cover will be under the tension of the spring. Also watch for spring spacer(s) that may fall out, you may not have any but you never know. I'd also mark the cover to the sliding sheave so that I install in the same orientation, I believe I've seen what looks like factory markings on some of them, but they may get worn off.
