indy
- Nov 27, 2004
98 vmaz dlx 700 XTC. I've had the carbs off dozens times, but some how this time I messed up the coil wires. I am hoping someone can post a good pic for me to view so I can fix this. Sled is running at high rpms and drops some and then runs back up. ? Second cleaning so far.
Throttle cable too tight, or other issue with the throttle mechanism, keeping the carbs open a bit?
Air leak?
Pull you plugs and check for spark on all 3, if they are firing you likely don't have a coil issue. If they aren't all firing it seems like the engine wouldn't run to high rpms, nor back and forth lower to high.
Air leak?
indy
- Nov 27, 2004
its the small gauge wires coming from the coils I am concerned. Still does it with the choke and throttle in a slacked position.
SX600abuser
Throttle cable adjusted wrong cause tors to activate?
