howsahemi
howsahemi
snowdad4
split the clip between the washers and test. since no two sleds are equal, thats a good starting point then adjust from there.
just did one the other day and that half position either way made for a bog on the first 1/4 or so throttle. raised the needle and it went away.
howsahemi
Is there already two washers on the needle? Or do I need the kit before I do anything?
snowdad4
pull your needles out and see. it may have been changed. find the washer(s) and measure them. .8mm is standard, .4mm is what you want. .4's are found on most from 97 up. i most likely have a few.
howsahemi
Ok I'll take a look. Thanks for your expertise once again! I'll let you know if I need some washers.
A couple of bucks
I know it says it's for a 95/95 Vmax 500/600. Could this be safely applied to a SX500R to help eliminate the 0-1/4 throttle bog.
I should also add that it is stock except for SRX/Viper reed cages. Mid & top end are great.
A couple of bucks
To answer my own question, it most definately did. Bog completely gone.I know it says it's for a 95/95 Vmax 500/600. Could this be safely applied to a SX500R to help eliminate the 0-1/4 throttle bog.
