averagesleder
So I did all the preseason stuff, cleaned the carbs, powervalves, fresh fuel etc etc. The problem now is the idle is at 4000rpm and will not go down at all, even with the idle screw turned all the way out. It does come down with the choke on but as soon as I take it off it climbs back up right away. There is slack in the throttle cable and I drove it with the idle high and it seemed good, the throttle was responsive like it should be. The fuel filter was replaced 2 seasons ago. TORS is disconnected, has been for years. Plugged the TORS in and then it sounds like a rev limiter is kicking in.
It was also a bit hard to start after we cleaned everything and took some starter fluid to get it going( i know we shouldn't) it started fine once warm though.
Just started it again with choke,engine was cold(now started good). But as soon as the choke is off the idle climbs back up to 4000rpm.
Any ideas?
Any ideas?
